1 members (78buckshot),
43
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18803 12/05/2001 3:25 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I would like to mount 235/85R16 size tires on my stock '53 Chevy rims. My question is whether the rims are wide enough? Also should I use inner tubes since the rims are rivited? | | |
#18804 12/05/2001 3:33 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Stock rims are 5.5 inches, the book shows a 6.0 to 7.0 width for the tire. It should work. I don't know what you mean by riveted rims, though. I would go to a local tire dealer who handles truck tires. They should be able to answer your questions.
Fred 52 3600 69 C-10
#18805 12/05/2001 10:39 PM | Joined: Jan 2001 Posts: 1,419 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,419 | I've been running that size on my stock rims for a year and a half. '49 3100
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#18806 12/05/2001 11:35 PM | Joined: Aug 2001 Posts: 13 Member | | Member Joined: Aug 2001 Posts: 13 | Can't argue with the experience of Cosmo, but 6 to 7 inches is what most of that tire size requires and the stock rims I've seen measure 4.5. Best to follow Fred's advice on local tire shop input. Measure twice, mount once. | | |
#18807 12/06/2001 12:09 AM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | How much of a difference do radials make over biased ply tires in handeling and ride on these old trucks.
1942 1/2ton 1951 1/2 ton 1960 biscayne sedan 1968 ihc scout 1972 #### 3/4 ton
#18808 12/06/2001 5:06 AM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Radials were the best thing I did to improve the handling of my truck. Stock rims do measure 4.5 inches and the tire shop will likely tell you it can't be done, but it can. IMO 16's sometimes look balooned on 4.5 inch rims. They may also tell you that you need tubes, but I haven't lost air for years at a time. I didn't use 16 inch rims, but went with later Task Force 15 inch rims and 7.50 or 7.00' by 15's. These rims measure 5.5 wide and take the stock caps fine. Another option is to have some rims made or modified, I have heard of this being done for prices that are reasonable.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
#18809 12/07/2001 5:09 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Hey, thank for the input on mounting radials on my stock rims. What I meant by rivited rims, was how the center section is mounted to the outer rim. Newer rims have the center welded to the outer rim, but the ones for my truck are riveted to the outer section. I know radial tires make a big difference in handling. My '70 Chevy Nova had bias ply tires and was all over the road. I mounted radials and it goes straight down the road now. | | |
#18810 12/07/2001 6:54 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Those rivets should be air-tight. Let the dealer mount one, then dunk it in the water tank to check for leaks, just to be sure. Then you can decide if you need tubes.
