1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
#18803 12/05/2001 3:25 AM
I would like to mount 235/85R16 size
tires on my stock '53 Chevy rims. My question is whether the rims are wide enough?
Also should I use inner tubes since the
rims are rivited?
#18804 12/05/2001 3:33 PM
Stock rims are 5.5 inches, the book shows a 6.0 to 7.0 width for the tire. It should work. I don't know what you mean by riveted rims, though. I would go to a local tire dealer who handles truck tires. They should be able to answer your questions.
Fred
52 3600
69 C-10
#18805 12/05/2001 10:39 PM
ODSS President
ODSS President
I've been running that size on my stock rims for a year and a half. '49 3100
~ Cosmo
1949 Chevy Half Ton
#18806 12/05/2001 11:35 PM
Can't argue with the experience of Cosmo, but 6 to 7 inches is what most of that tire size requires and the stock rims I've seen measure 4.5. Best to follow Fred's advice on local tire shop input. Measure twice, mount once.
#18807 12/06/2001 12:09 AM
How much of a difference do radials make over biased ply tires in handeling and ride on these old trucks.
1942 1/2ton 1951 1/2 ton 1960 biscayne sedan 1968 ihc scout 1972 #### 3/4 ton
#18808 12/06/2001 5:06 AM
Radials were the best thing I did to improve the handling of my truck. Stock rims do measure 4.5 inches and the tire shop will likely tell you it can't be done, but it can. IMO 16's sometimes look balooned on 4.5 inch rims. They may also tell you that you need tubes, but I haven't lost air for years at a time. I didn't use 16 inch rims, but went with later Task Force 15 inch rims and 7.50 or 7.00' by 15's. These rims measure 5.5 wide and take the stock caps fine. Another option is to have some rims made or modified, I have heard of this being done for prices that are reasonable.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
#18809 12/07/2001 5:09 AM
Hey, thank for the input on mounting radials on my stock rims. What I meant by
rivited rims, was how the center section is
mounted to the outer rim. Newer rims have the
center welded to the outer rim, but the ones
for my truck are riveted to the outer section.
I know radial tires make a big difference
in handling. My '70 Chevy Nova had bias ply
tires and was all over the road. I mounted
radials and it goes straight down the road
now.
#18810 12/07/2001 6:54 AM
Those rivets should be air-tight. Let the dealer mount one, then dunk it in the water tank to check for leaks, just to be sure. Then you can decide if you need tubes.
Fred
52 3600
69 C-10
