6 members (Millenimech, mason86, delky, UtahYork, Otto Skorzeny, 1 invisible), 65 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#18792 03/04/2003 2:46 AM
I am just putting together a repair on the Axle eye ends .
The caps that are tapped down onto the ends of the spindle holes , to retain the grease and keep the weather out , are normally mild steel .
These caps are not available locally ,, will it be ok to use brass freeze plugs instead ?
Any thoughts appreciated . smile
#18793 03/04/2003 3:18 AM
Those soft plugs normally come as part of the king pins replacement assy. along with the tapered retainer bolt, thrust bearing and endplay shims. If all you have are brass soft plugs then it will be OK to put then in.
kdot em3
#18794 03/04/2003 9:01 AM
I have had the axle eye end machined and bushed , refitted the original kingpins , put new shims and cotterpins in . Not a proper king pin replacement job ,, just needed the eye ends done ,, so I didnt use a new kit . Hense the question about the end caps .
Thanks for your thoughts RCD . smile
#18795 03/10/2003 6:22 PM
Dusty: Did you have any luck finding dust caps for your spindles:(King Pins) Local Auto blank just looked at me and laughed. Tried asking for 1 1/8 freeze plugs but they had 1" & 1 1'4" I guess I'll make my own unless you or somebody can help! popcorn
#18796 03/11/2003 12:40 AM
Yes , I got some steel freeze plugs , they just had to come from out of town ,, well ,, I'm out of town too , so that's a moot point , LOL . But it is all fitted up and working now . smile
PS , Do you need me to send you some?
#18797 03/14/2003 9:52 PM
No Dusty thanks tho: I ended up making caps at our shop, my electrician gave me an idea and I took it from there. POPCORN
