| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | hey.all..well i bought a 50 chev panel truck last week,,1 ton ,i think ,,anyway it has 17" inch tires,,one of the wheels is a F@rd rim....8 hole..where can a guy get a good price on these tires,,oh yeah,,they are Split Rims too...  | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Check with your local tire shops about the rims. Up here, they won't work on split rims, period. | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | I bought my split rims and a set of new tires from Toms Truck Parts in Miami Oklahoma. He made me a good deal on the tires since I bought six wheels. He looked through a lot of wheels to get six good ones that matched. No tire shop will work on them. They dont remember how to do it without getting hurt but you can do it if you know how.
I like old trucks
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Automotive tire shops won't do it - find the guys who work on big stuff like dump trucks. They should have the proper equipment and know-how. | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | "panel" is on the right track. my 50 3/4 ton has the 17"s and for the most part the guys at the local "big truck" tire place are relatively amicable to working on them.
are they split rim or lock ring? mine are the lock ring style and they actually are not that bad to work on.,,and way safer than the split rim. lock rings seat up in a more positive nature than a split rim. my dad had a 69 gmc with split rims. we tied straps around and through the rims when we mounted a new set of tires up before puttin air to them. never did have one test the straps capability but sure didn't want to take the chance. still not a bad idea if it's your first time beading one up.
i changed a flat about 2 months ago and decided to do it myself. best advise i can give you is make sure to put a heavy solution of soap around the rim to ease the removal of the tire from the ring. once the soap was worked into the ring it slid right off.
it also helps to make a block spacer to put under the tire/rim assembly. if it's sitting on the floor you'll never get it broke free.
the chevrolet truck shop manual for 48 to 52's outlines tire removal procedures pretty well. | | |
