| | | Forums66 Topics128,081 Posts1,056,075 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | my 53 gmc has only 3 fuses as far as i can tell. 1 for the tail lights, 1 for the brake lights and a 30 amp breaker inside of the light switch. i'm not sure if i need to fuse any or all of the following: cig lighter horn relay ammeter heater fan etc. thanks for any help on this safety matter. tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | IMO, every wire should be fused. It really isn't the lighter, lights or any other function that should be protected, just the wire itself. That will keep things from burning in case of a short. | | |
