5 members (ShopRag, kurbside bolter, Ponchogl, cmayna, 1955 1 Series), 107 guests, and 4 robots.
Topics128,268
Posts1,058,375
Members48,485
#18687 03/06/2004 6:05 AM
I am looking for information about the frame for my 38 chevy 1/2 ton. I have ended up with a truck that needs a new front frame section, cab forward. The previous owner tried to install a Nova clip, didn't work very well. I bought the truck as is because it is what I wanted. The chassis seems to be the problem at the moment. Can anyone help?????
#18688 03/06/2004 3:32 PM
If you can wait a couple of years I will have a extra frame as I bought another frame to install a MII front and go with a modern rearend while stll being able to drive my truck. It will be at least another year before I start on it as I have to finnish another project,there is someone who makes aftermarket frames for those trucks and I think its progressive automotive in new balitimore ohio and if I have it wrong hopefully there is someone who might know. I think I read somewhere that the frames are similar up to 46 and a local junkyard has a 41 in it that I think the front part is good but from the middle of the cab on back is very rusty. Jeff grin
