7 members (papas52, klhansen, Shade Baby, 1955 1 Series, Still At It, Bill Hanlon, 1 invisible),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | Has anyone ever installed an open differential in their torque-tube rearend? | | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | There are a lot of posts here about this; use the search function under the NEw Post icon. I bought a 3.90 for this very reason for my 47. I never used it though, as I'm switching to a more modern axle.
jay
Your lack of preparation is not my emergency
| | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | Guess I'm not typing in the write words...nothing comes up. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | There are two search links - one to search the forums and one to search the web site. Use the forum search. The forum search is below the "post new topic" and "post new reply" graphics near (but not at the top) of the page.
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's been discussion about putting the TF years rear gear in the AD - the axles are the same and maybe the punkin is interchangeable, but I think the only thing that has to be modified to use the whole axle is the spring mount oldblu49 discussed it - search for his posts
Bill | | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | I tried both search links...none of my "rear end" wording seemed to bring anything up. I'll try it again.
Basically, I realize the exterior modifications that are required, but I wasn't sure if there were any internal issues other than exposed inner axle bearings. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | R.F. you can use the center section from a TF axle in the AD housing. This way you can keep the existing e-brake linkage and won't have to worry about spring mounts. BUT you will have to set your pinion angle and then weld the pivot pins on your spring mounts so they no longer rotate or twist. I have not yet done this but have the necessary parts courtesy of Bill at red58. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Go to the "Engine & Driveline Shop" Forum and type in "3.38" in the search. | | |
