0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 25 Junior Member | | Junior Member Joined: Mar 2005 Posts: 25 | My front brakes are locking up after 20 miles, do I ajust the master cylender front rod in or out to get rid of this problem? its on 58 chev 3600. Much thanks Joe :confused:
annalei0
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | out I'd think - needs a bit of free travel on the pedal before it starts to push the cyl, but if the rubber brake hoses at the front aren't new, they could be the problem - the inside rubber can swell and prevent fluid release
Bill | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | Joe, i adjust mine whichever direction gives me about 1 inch of travel in the brake pedal before it hits brakes! this is what i do when i do brakes, in this order: -bleed the brakes, refill the reservior -disconnect the rear emergency brake cables -adjust each wheel till i feel a grinding and then back it off 14 clicks (check the manual for your amounts) -adjust master cyclinder rod to give me 1" of free pedal. -engage the emergency brake 1" and then turn the adjusting screw on each of the emergency brake cables until you take up the slack and feel the shoes hitting the drums -hook back up the 2 rear emergency brake cables with the pin and cotter pin. -check all four wheels to ensure there's no dragging on any of the wheels. -check to see if you have good brake pedal (at least 3 inches before it hits the floor and also good emergency brake pedal, at least 1 inch before it hits the floor
this is all assuming you've removed the wheels and inspected the drums and brake shoes and there are no brake fluid leaks and the shoes have good pads on them and the drums and pads don't have deep grooves in them which could 'lock' the shoes to the drum.
i think that's everything :-) tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Mar 2005 Posts: 25 Junior Member | | Junior Member Joined: Mar 2005 Posts: 25 | Thanks Bill an Tony You sent me in the right direction. Those are orginal hoses. But the truck only has 80,000 original miles, But I will replace them just for saftey reasons. I should know better at my age of 52 things do ware out.haha
annalei0
