0 members (),
118
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | I replaced my speedometer cable and it didnt make any difference on my speedometer needle, it still doesnt work with a new cable.
I assume I will need to replace the speedometer gauge itself to get things to work right or is there any other angle I should consider before I replace the gauge?
Anyone have a working speedometer gauge they can send me for a cheap price ?? It's for a '52 half ton. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I had a problem with mine some years back. It began to give me obvious incorrect indications of the speed I was traveling. I pulled the cable and cleaned it and lubricated it. It did not help so I took it to a speedometer shop and had it rebuilt. Since than, everything has been fine. You might need to have it rebuilt. Hope this helps! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | Make sure the cable itself goes in far enough to engage the speedometer mechanism, then take the cable from the tranny and chuck it in a drill to see if the speedo needle moves. If no movement, get one at a swap meet or try e-bay. If the needle does move, put the cable back in the tranny, amking sure it is engaging the nylon gear. Leave the cable unhooked from the back of the speedo. Then go down the road and observe if the cable itself is moving - a passenger would be helpfull to avoid accidents. If cable still not moving, then the nylon/plastic gear or worse yet, the internal gear may need replacing. The plastic gears can still be obtained, the internal gear may have to be replaced with a used one.
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
