4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
#185429 07/15/2005 2:55 AM
Hi Guys,
How valid is the 4200 lb weight listed in the shop manual for 1950 1/2 ton?
#185430 07/15/2005 3:48 AM
My '48 1/2 ton weighed 3k without the box.
Jason
#185431 07/15/2005 3:58 AM
I cant remember if mine was 3400 or 3900 lbs. The only thing I was missing was the bed wood and Spare tire. That and mine is a 49.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#185432 07/15/2005 4:47 AM
My '50 with spare weighs about 3600 empty but with a driver who probably eats too much.
Craig
#185433 07/15/2005 4:29 PM
Thanks guys...
#185434 07/15/2005 4:53 PM
X
X Offline
That 4200 lb. weight given in the shop manual load capacity chart is the gross vehicle weight rating (GVWR), not the empty curb weight, of the base truck with base tires. The actual GVWR (up to 4600 lbs.) depends on the tires used, as shown in the chart. Curb weight would be in the 3325-3385 lbs. range, according to Chevy specs, for the 1/2 ton AD's, not including any optional equipment.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
