4 members (Cosmo, dt235sd, Gray_Ghost, Gdads51), 84 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#185295 07/11/2005 7:03 PM
I
Junior Member
Junior Member
I Offline
I have a 1953 chev 1 ton flat deck.
I would like to mount the cab on a newer chassis, to make the vehicle highway capable and safe, and then add a correct pick up box.
Any suggestions on a chassis I could look for that wouldn't need major modifications?
If you have any ideas, please email me with suggestions.
Thanks.
Ian Horner
#185296 07/11/2005 8:46 PM
How are you going to use the truck? If you intend to keep the 1-ton load rating the answer is probably different than if you are looking to create a short-box 1/2-ton.
Does you 1-ton have dual wheels in the rear?
