| | | Forums66 Topics128,057 Posts1,055,812 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | I have a 1953 chev 1 ton flat deck.
I would like to mount the cab on a newer chassis, to make the vehicle highway capable and safe, and then add a correct pick up box.
Any suggestions on a chassis I could look for that wouldn't need major modifications?
If you have any ideas, please email me with suggestions.
Thanks.
Ian Horner
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | How are you going to use the truck? If you intend to keep the 1-ton load rating the answer is probably different than if you are looking to create a short-box 1/2-ton.
Does you 1-ton have dual wheels in the rear?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
