1 members (Otto Skorzeny),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 35 Junior Member | | Junior Member Joined: Jan 2003 Posts: 35 | has anyone installed the front sway bar (jim carters) on the 47-55 AD 1/2 ton. mine came with no instructions and i am clueless as to how it bolts on. well i am pretty clueless about most things so this should be no surprise. Anyway i did a search and did not find what i was looking for (instructions) so i am posting here.
thanks, jerry | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Mine came with no instructions either..Just call them, and they will email them...Don't get real excited though, the instructions are not real well done..Good luck, it's best to lay out all the parts first to figure out how it works..It'll be OK..Hardest part is getting the nuts off the u-bolts..Steve | | | | | Joined: Mar 2005 Posts: 18 Junior Member | | Junior Member Joined: Mar 2005 Posts: 18 | I have an OE sway bar (book calls it a stabilizer) I think I have the exploded view in my factory assy. manual. Would you like me to mail a copy if I have it? You may want to call Jim Carter to see if the one they'll send is from assy manual too. | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | The "search" link at the top of the page searches the web site (not the forum). The "search" link next to "post a reply" in the forum searches the forum. This is probably what you want: Sway bar
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2003 Posts: 35 Junior Member | | Junior Member Joined: Jan 2003 Posts: 35 | thanks for the replys. i will give jim carters a call, hopefully this week if time allows. I have the assembly manual but the diagram of the original bar looks like it may be installed somewhat differently than the jim carter model. I thought that I might get to the sway bar this weekend, but with my three college kids home for the summer plus my two high schoolers, the time just wasn't cooperating with my old truck plans. I hope to install the drag link today, and will take another look at the sway bar parts, perhaps I can make sense of them.
thanks, jerry | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | duddygoober,
So far, I think there could be at least four possible sway bars that have creeped into this discussion.
Used sway bars from a 47-55 AD truck (Jim Carter sells them). 1. 1947.5-1950/51 2. 1951-1955.5
A sway bar from an automobile (or later truck with a front swing-arm?): 3. Gord's link above to an earlier thread on this topic shows a posting of a non-AD sway bar - might be same vintage automobile?
An aftermarket sway bar 4. Jim Carter, HP154, SWAY BAR ASMBLY 47-55 1ST 1/2 TON, for example
My guess is that each of the four assemblies have a different installation configuration. Your call to Jim Carter should clarify this.
Tim | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have a front sway bar that I took off a 1955 Suburban. It will take a little adapting to fit on my '54 GMC, but I will install it, seems like everyone that has one likes it. | | |
