2 members (baldeagle, 78buckshot), 61 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
Ok guys lets hear it.
I finished my total rebuild from frame up, O/H engine and what ever needed tobe done. Basically every piece on the truck was cleaned painted or replaced.
Engine runs smooth and quite, even the local experts can't belive how smooth the engine runs.
After highway driving and pulling up on the drive way I have instantly a puddle under the rear engine seal.
yesterday I pulled the seal and replaced it with a new one. it,s better than befor, but still the truckmarks his teritory. I opted for the orange silicon seal, should I used the old rope seal
(since they did not have silicone in 1953).
I followed each step on how to change rear main seal, in the tech tips forum.
Steering box needs to be tighter.
Have to chase some rattles under the dash
realigne hood and doors.
otherwise all is well. smile
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
I have had similar problems with the rear main seal. I used the cork seals (this was several years ago) and finally got it under control by trimming ends that were slightly too long and using silicon sealer generously. How 'bout if you back into driveway?
One who knows that enough is enough will always have enough. Lao Tzu
Oly Offline
Fritz, if you can get the old asbestos rope seal it will work best. It is tried and proven to be better. I think if you use it you problem will go away.
ps.
If you need some pointers on that steering box drop me a line.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
