1 members (klhansen),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 5 Junior Member | | Junior Member Joined: May 2005 Posts: 5 | Hello, I have a 1951 Chevy Suburban that I recently picked. It has the original suspension that I would like to lower without using a dropped axle. Anyone have any suggestions, if I can lower it about 2&1/2" I'll be able to get it in my garage. I will be changing tires on it soon and that will drop me about 1/2" or so. I plan on driving it as is until I finish the other frame with all new and modern stuff. The reason I dont want to go with a dropped axle is I just bought a Mustang II setup for the other frame and I dont want to buy anything twice for this project. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You can bring the back down using lowering blocks. I stopped by a scrap metal place last week and for $7.00 picked up some blocks of scrap aluminum that would be great for that purpose (not what I bought them for though).
The front is harder. I'm not aware of a cheap way to lower the front that is also safe and same.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 5 Junior Member | | Junior Member Joined: May 2005 Posts: 5 | I already have blocks for rear, it's the front that i'm stuck on. if you come up with any ideas i'd love to hear them. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well you might look for real low profile tires...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | You could remove a few leafs from each spring pack in the front to lower it a little. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't like the remove some leafs approach.
Suburbans lean a lot on corners already, and need the spring stiffness along with a sway bar to help them feel like they will stay upright.
The leafs are about a quarter inch thick, so removing two would be about half an inch. There are only eight total, so getting a 2-1/2 inch drop removing leafs isn't in the cards...
Re-arching the springs and reversing the eyes might be an idea.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 60 Member | | Member Joined: Feb 2005 Posts: 60 | Truck Shop has reverse eye main leafs for around 40 bucks a peice than pull 2 leafs out. Those were way over sprung for todays roads and loads. Just make sure the shocks have travel and dont bottom. You have a sway bar i bet so you will be fine. Shorter tire,reversed mains with 2 leafs gone will get you close. Becarefull using aluimn blocks. You would be better to make new perches out of 2x3 tubing. | | | | | Joined: May 2005 Posts: 5 Junior Member | | Junior Member Joined: May 2005 Posts: 5 | I love this forum, Thank you all for the great info. | | |
