0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#184898 07/05/2005 7:17 PM
Junior Member
Junior Member
Hello,
I have a 1951 Chevy Suburban that I recently picked. It has the original suspension that I would like to lower without using a dropped axle. Anyone have any suggestions, if I can lower it about 2&1/2" I'll be able to get it in my garage. I will be changing tires on it soon and that will drop me about 1/2" or so. I plan on driving it as is until I finish the other frame with all new and modern stuff. The reason I dont want to go with a dropped axle is I just bought a Mustang II setup for the other frame and I dont want to buy anything twice for this project.
You can bring the back down using lowering blocks. I stopped by a scrap metal place last week and for $7.00 picked up some blocks of scrap aluminum that would be great for that purpose (not what I bought them for though).
The front is harder. I'm not aware of a cheap way to lower the front that is also safe and same.
Junior Member
Junior Member
I already have blocks for rear, it's the front that i'm stuck on.
if you come up with any ideas i'd love to hear them.
Well you might look for real low profile tires...
#184902 07/06/2005 11:49 AM
You could remove a few leafs from each spring pack in the front to lower it a little.
I don't like the remove some leafs approach.
Suburbans lean a lot on corners already, and need the spring stiffness along with a sway bar to help them feel like they will stay upright.
The leafs are about a quarter inch thick, so removing two would be about half an inch. There are only eight total, so getting a 2-1/2 inch drop removing leafs isn't in the cards...
Re-arching the springs and reversing the eyes might be an idea.
DJ Offline
Truck Shop has reverse eye main leafs for around 40 bucks a peice than pull 2 leafs out. Those were way over sprung for todays roads and loads. Just make sure the shocks have travel and dont bottom. You have a sway bar i bet so you will be fine.
Shorter tire,reversed mains with 2 leafs gone will get you close. Becarefull using aluimn blocks. You would be better to make new perches out of 2x3 tubing.
Junior Member
Junior Member
I love this forum,
Thank you all for the great info.
