1 members (delky),
127
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | I just got a '57 and it has Trico wiper blades. I can't find the 12" refills anywhere. I emailed Trico, but no responce yet. Any recommendations are appreciated. Thanks.
Follow up - the response from Trico is that the arm and blade are inseparable. So, the part # is 60750; available at/through NAPA.
Thanks for you help.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | take an old one to NAPA, they should be able to come up w/ somethin you can cut down - also try marine stores, as the marine wipers are quite similar to our older styles
Bill | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Isn't there a tech tip here about that? | | | | | Joined: Apr 2005 Posts: 5 New Guy | | New Guy Joined: Apr 2005 Posts: 5 | I've seen a tip for AD's somewhere.
The Filling Station has TF wiper blades that take refills ($3.50 per refill, but cheaper than blades) Hopefully, they can be refilled with cut-down modern refills. | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | You might also try taking your blade to the parts dept of your local "big truck" dealer-i.e. Freightliner, International, etc. The wipers used on many of these new trucks with flat glass should work just fine on an oldie. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
