3 members (klhansen, 2-Ton, Bill Hanlon), 111 guests, and 3 robots.
Topics128,193
Posts1,057,253
Members48,466
V
VEW
Offline
V Offline
I just got a '57 and it has Trico wiper blades. I can't find the 12" refills anywhere. I emailed Trico, but no responce yet.
Any recommendations are appreciated. Thanks.
Follow up - the response from Trico is that the arm and blade are inseparable. So, the part # is 60750; available at/through NAPA.
Thanks for you help.
~ Victor
1957 3100 - moved on
take an old one to NAPA, they should be able to come up w/ somethin you can cut down - also try marine stores, as the marine wipers are quite similar to our older styles
Isn't there a tech tip here about that?
1954 GMC De Luxe COE
I've seen a tip for AD's somewhere.
The Filling Station has TF wiper blades that take refills ($3.50 per refill, but cheaper than blades) Hopefully, they can be refilled with cut-down modern refills.
You might also try taking your blade to the parts dept of your local "big truck" dealer-i.e. Freightliner, International, etc. The wipers used on many of these new trucks with flat glass should work just fine on an oldie. cool
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
