6 members (55shaker, 54farmtruck, Hotrod Lincoln, Bill Hanlon, MNSmith, 1 invisible), 118 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
#184794 07/04/2005 5:18 AM
I just got a 1959 gmc with a badge and a 350 engine with a 4 speed truck tranny. I am wandering if the motor and tranny are installed in a stock fashion. So what i need is good pics of your v8 trucks to see what they look like.
a badge? like a "350" badge? more likely a model number or it was added w/ the 350, which weren't made in 59
don't have a mount pic handy, but the shop manual should tell ya - if it's mounted as original, it's got 2 wimpy lookin pegs from the front of the block to riveted on mounts on the front crossmember, and the bellhouse has ears that mount on the cross member there - the tranny hangs off the bellhouse - more likely w/ the 350, they put a cross member under the engine at the point where the side mounts are, which is a standard aftermarket conversion
here's some good pics of my V8 truck grin
I guess only gmc came with a v8 badge on the side next to the gmc logo.
are v8 trucks in 58 and 59 open or closed driveshaft
Chevys had a small V on the door, and a large V on the hood ornament, no 8 invloved like this 57 - correct hood trim on my 58 here , I skipped the door ones - I think GMCs had a V right under the GMC on the fender, not sure on the "8" - real trucks are all open drive grin [after 55]
I
I Offline
my grandpa has a stock 59 gmc i can get pic this weekend
rh
I
I Offline
didn't make it to the truck to get pictures but it sould have a pontiac v8 instead of chevy hope that helps
don't know when i will get near the truck
rh
