| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | I just got a 1959 gmc with a badge and a 350 engine with a 4 speed truck tranny. I am wandering if the motor and tranny are installed in a stock fashion. So what i need is good pics of your v8 trucks to see what they look like. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a badge? like a "350" badge? more likely a model number or it was added w/ the 350, which weren't made in 59 don't have a mount pic handy, but the shop manual should tell ya - if it's mounted as original, it's got 2 wimpy lookin pegs from the front of the block to riveted on mounts on the front crossmember, and the bellhouse has ears that mount on the cross member there - the tranny hangs off the bellhouse - more likely w/ the 350, they put a cross member under the engine at the point where the side mounts are, which is a standard aftermarket conversion here's some good pics of my V8 truck Bill | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | I guess only gmc came with a v8 badge on the side next to the gmc logo. | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | are v8 trucks in 58 and 59 open or closed driveshaft | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Chevys had a small V on the door, and a large V on the hood ornament, no 8 invloved like this 57 - correct hood trim on my 58 here , I skipped the door ones - I think GMCs had a V right under the GMC on the fender, not sure on the "8" - real trucks are all open drive  [after 55] Bill | | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | my grandpa has a stock 59 gmc i can get pic this weekend rh | | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | didn't make it to the truck to get pictures but it sould have a pontiac v8 instead of chevy hope that helps
don't know when i will get near the truck
rh | | |
