| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | I had the 53 gmc 1/2 ton on the rack today and noticed the drag link is frozen in a 45 degree angle and doesn't seem to want to pivot on the balls as I'm sure it should. is this a problem? do i have to replace the drag link? how big of a job is this? any help is appreciated as always. tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I would take it all apart first, look for warn out parts and replace as necessary. It could be that it hasn't been greased in a long thime and it's gumed up. If your pivot balls ard not egg shapped and the internal parts look good, grease it up and put it back together. Hope this helps George | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | 46forme, unfortunately it appears i have the 100-22 model 1/2 ton that doesn't have an adjustable drag link. i forced it back to neutral position, but it cranked itself back to the 45 degree angle cock straight away. hopefully, it won't pop off at an inopertuned moment! thanks for your help tony
