2 members (Gdads51, 1 invisible), 92 guests, and 0 robots.
Topics128,052
Posts1,055,743
#184705 07/01/2005 10:43 PM
I'm not hitting the right words I guess. I'm trying to find the soild blue air supply lines with black hand tightened fittings to run air supply around my shop. Where do I find it on the wwweb?
Thanks, Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#184706 07/01/2005 11:28 PM
what's color got to do with it? grin something you've seen in a shop?
how about just using black iron pipe or copper or a good quality hose reel?
ya might wanna look at a tools place
or try different wordings from here
#184707 07/01/2005 11:52 PM
Color is not special, just what I saw on TV. Its aluminum with easy plastic fittings, 250 psi, take apart, move, change. Just want to find it to get more information.
Buddy
'50 GMC Suburban
#184708 07/02/2005 12:27 AM
X
X Offline
They showed that piping system on Trucks! TV. It's by Garage-Pak.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#184709 07/03/2005 8:21 AM
Buddy in AK, I would rule out plastic because of your location..... If you want a simple do-it-yourself system, use schedule L or K copper pipe. It's easy to assemble and it's lighter than black pipe. I doubt that you are designing an elaborate system with lot's of outlets, so it's your choice on which material to use. It may be the cost that is the deciding factor and black pipe may be the way to go. I did some research and found a few articles/sites that may be of interest to you. I like the Garage Pak System. however I do not know the cost, availability or durability of the system. Maybe Ken Brown will jump in, I believe that this is his field of expertise. grin ....g
Garage Pak
Compressed Air Systems: The Secret is in the Pipe
Compressed Air Tutorial
OSHA
Plumb your plant air system with Thermoplastic pipe
WOODWEB: Compressed air delivery system
#184710 07/05/2005 7:35 PM
Thanks Gang, Garage Pak is what I was looking for. When I build my shop I want as much as possible in the orig. budget. I think this system will get air where I need it and will be easy to change or move as needed.
Buddy
'50 GMC Suburban
#184711 07/06/2005 4:46 PM
My system which works jusst fine is a compressor on wheels, I can put it anywhere needed, just need a long extension cord.
#184712 07/06/2005 11:43 PM
Junior Member
Junior Member
quick note on air lines;
DO NOT USE PVC! PVC turns into schrapnel if it ever breaks or gets punctured, cracked, etc. There are other plastic piping sytems that can be used.
I saw that Trucks episode with the Garage-Pak system. It was pretty nice and seemd like it was really easy to work with.
Good luck on getting your shop set up like you want it
Bobby
