| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | I'm not hitting the right words I guess. I'm trying to find the soild blue air supply lines with black hand tightened fittings to run air supply around my shop. Where do I find it on the wwweb?
Thanks, Buddy | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what's color got to do with it?  something you've seen in a shop? how about just using black iron pipe or copper or a good quality hose reel? ya might wanna look at a tools place or try different wordings from here Bill | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Color is not special, just what I saw on TV. Its aluminum with easy plastic fittings, 250 psi, take apart, move, change. Just want to find it to get more information.
Buddy | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | They showed that piping system on Trucks! TV. It's by Garage-Pak.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Buddy in AK, I would rule out plastic because of your location..... If you want a simple do-it-yourself system, use schedule L or K copper pipe. It's easy to assemble and it's lighter than black pipe. I doubt that you are designing an elaborate system with lot's of outlets, so it's your choice on which material to use. It may be the cost that is the deciding factor and black pipe may be the way to go. I did some research and found a few articles/sites that may be of interest to you. I like the Garage Pak System. however I do not know the cost, availability or durability of the system. Maybe Ken Brown will jump in, I believe that this is his field of expertise.  ....g ********************************************* Garage Pak Compressed Air Systems: The Secret is in the Pipe Compressed Air Tutorial OSHA Plumb your plant air system with Thermoplastic pipe WOODWEB: Compressed air delivery system | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Thanks Gang, Garage Pak is what I was looking for. When I build my shop I want as much as possible in the orig. budget. I think this system will get air where I need it and will be easy to change or move as needed. Buddy | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My system which works jusst fine is a compressor on wheels, I can put it anywhere needed, just need a long extension cord. | | | | | Joined: Apr 2005 Posts: 11 Junior Member | | Junior Member Joined: Apr 2005 Posts: 11 | quick note on air lines; DO NOT USE PVC! PVC turns into schrapnel if it ever breaks or gets punctured, cracked, etc. There are other plastic piping sytems that can be used.
I saw that Trucks episode with the Garage-Pak system. It was pretty nice and seemd like it was really easy to work with.
Good luck on getting your shop set up like you want it
Bobby | | |
