| | | Forums66 Topics128,050 Posts1,055,632 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Trying to get the drivers side door installed for a test fit/adjust, I managed to strip some threads. One of them is in the top hinge of the door - the threaded plate cracked - However, I think that there is enough room to drill out the plate and use a nut behind it and still have the glass move. Anybody done this? Did it work OK? The other one is in the door jamb and I can't see how to fix it other than cutting an access hole in the sheet metal  - I need some ideas here. Thanks.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Gord, The top hinge strap can be welded and re-tapped if need be. I have a couple of extra hinges though if you need one. The other problem is a bit trickier to solve. The hinge basket in the door jam is not reproduced but I also have a couple of these saved from a previous donor. Try to run a regular size tap through it and see if that will work. If not you can jump up a size and try that. I think those are 3/8 threads. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I was lucky because I ran a tap through all of mine and they all cleaned up. However, I have given some thought to the potential problem that you now have experienced. I am wondering if there are some metric sizes that are in between the standard sizes such that one could tap it out just a little. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Helicoil. http://www.toolsource.com/ost/product.asp?sourceid=googlehelicoil&dept%5Fid=500&pf%5Fid=72428&mscssid=UJCR5W7EV8C28LETPFWJ38MX099N2W9D | | | | | | Anonymous Unregistered | | Anonymous Unregistered | ^^ Yup. Heliocoils are good things. I have not used them on something as big as a door though. | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Thanks everybody.
Houston, thank you for offering replacement parts. However, I think I can make do with the ones I have. The threads are in a plate welded to the inner door skin - the holes in the hinge strap are slotted for adjustment. Looking at it again, I realize I forgot about the ventipane window - so it looks like a installing a nut wouldn't interfere with the window or latch mechanisms.
I thought about helicoils for the stripped thread in the jamb cage. I heard some engine builders drill out perfectly good threads in engine blocks and use helicoils for the head bolts - supposed to give more even torque :confused: So, I know they will work if I want to install the door once and forget about it. However, I expect that I will have to install and remove the door many times before I done (for modifications, painting, adjusting, more modifications etc...) Will helicoils stand up to multiple assembly/disassemblys and all the tighten/loosen/tighten cycles during adjustment? Sounds like they are just the ticket if they will take the abuse...
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Yes, Helicoils work great with repeated bolt remove/install cycles. | | |
