2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#184496 06/29/2005 4:57 AM
Tab
Offline
I need a new, York AC compressor for my 3/4 ton. Where can I get a new or quality rebuilt one, cheap?
delete my account and pictures
#184497 06/29/2005 6:17 AM
B Online: Content
Price Quality Service Pick 2
Well that is what the sign in an old Hardware store said. You can have any 2 that you want but you can't get all 3.
I don't have an answer for your question as to where to get one but I would suggest talking to the local auto a/c mechanics in town and asking them where they would buy parts for there car, not the customers car but their car. That should tell you where to go. Good luck!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#184498 06/29/2005 2:08 PM
I put a used one from U-Pull-it on my 1-ton, I got tired of "new" & remans sounding like they are fulla marbles, usually from the start. I had one "new" York pop the belt on the freeway after one week. This used one is great, quiet. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#184499 06/29/2005 10:23 PM
Tab
Offline
Thanks, I may have to go to the junk yard....and it's 100º. darn.......
#184500 06/30/2005 12:12 AM
Tab, you can buy a "shoe" that will bolt onto the York compressor mount and convert it over to a Sankyo. The little adapter shoe is about $35.00 and you can go to a Sankyo or any number of those style compressors. I think you will also find that those type compressors steal less horsepower from your vehicle's engine.
Joe wink
#184501 06/30/2005 3:58 AM
Tab
Offline
6cylindersovertexas: Thanks, but yes I knew that. I'm concerned about my fittings matching the new rotary compressors. I don't want to have to buy new hoses. Regardless, I may go with a York to Sanden conversion setup if I can't find a cheap York.
Your point about the power loss is well taken. My 3/4 ton needs every horse that the 235 can muster.
#184502 06/30/2005 3:59 AM
I agree with 6overtexas. 40 years ago all the after marked add-on A/C units used York (fOORD) compressors. Today they mostly use Sanden (Sankyo-same thing), which was originally designed by a guy from TexAs. Belts always flop like crazy with the 2 cyl York. Thousands of VW Jettas in the wrecking yards use the 505 or 508 Sanden. 5 cyl.-5 cu. in. would be better than 8cu. in. unless you upgrade to a much bigger, newer, more efficient condenser. With 134A, bigger is not better for compressors.
'67 GMC 3/4 292 4spd
#184503 06/30/2005 4:07 AM
If you have any of the old hose clamp fittings and had the R12, you'll have to change the fittings for the 134 anyway.
