2 members (Ponchogl, Otto Skorzeny), 72 guests, and 1 robot.
Topics128,034
Posts1,055,548
Members48,425
#184476 06/28/2005 7:08 PM
Junior Member
Junior Member
I have a 1953 Chevy half ton pick up with what I was told was a 56 235 inline six. After identifing the engine code I determined it was a 59. I ordered the water pump for it from the casting number on the water pump and by engine number and the pump fit except it is about 1 inch longer than the original pump.
I looked at another forum and there was another 53 truck owner asking the same question and one suggestion other than ordering a short shaft version pump was to press the hub on further and cut off the excess shaft. Does anyone have an idea how to do this?
#184477 06/28/2005 10:40 PM
Riding in the Passing Lane
When a 55 up 235 is installed in an earlier truck you must use a shortened water pump. I believe the instructions are in the tech portion of this websight. smile
1972 Chevy c10 Cheyenne Super
