| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi, Will a t5 fit behind a 302 or 305 engine in a Chevy 1946 pickup ?
Cheers
jan | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'm sure the T-5 would fit, my 46 has the T-5 back of a six. Since you will have to modify the motor mounts, crossmember etc. to make the V8 work the trans should be the easy part. | | | | | Joined: Apr 2005 Posts: 28 Junior Member | | Junior Member Joined: Apr 2005 Posts: 28 | can't speak to the 302 since i don't know much about ford v-8's, but i'm putting a t-5 behind a 350 in a 39/42/46 (it's a mixed mongrel of a truck).
from what i've learned about the swap so far, the combination of parts you should be looking for will be a "world class" T-5 (it's a later version of the T-5 that has better bearings and other internals) out of a v-8 car like a camaro, and a junk s-10 transmission that has the shifter further forward on the tailshaft (otherwise, it lands in the seat). if you're running a mechanical speedometer, you'll have to find an s-10 trans with a mechanical speedo, and move the gear up on the shaft coming out of the camaro box.
it's a relatively straightforward deal to swap the tailshaft housings. I'm going to run mine with a hydraulic clutch actuated by a wilwood pedal, master, and slave cylinder. | | | | | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | Got a Camaro t-5 in back of a 283 in my '39 coupe. Its a great combo. | | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | Chevy made a 302 in the late 60s. they were powerfull, high rpm beasts. it was made so camaros could race in SCCA's Trans-Am Series, which had a limit of a maximum of 305 cubic inches.
it had the 327's bore of 4.0" and 283's stroke of 3.0"
50 chevy 3100
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Yenko made these camaros that would run 10,000rpms..Saw one in ElPaso in 1970..Could not believe the sound of that motor..Had a 396 69 Chevelle, and did not even think about a race | | |
