3 members (1955 1 Series, TUTS 59, 1 invisible),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,934 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 7 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 7 | I got some after market shackles, they seam to have more play than the ones I took out (made in china),I'm going to send them back, does any one have a good supplier for shackles I also need a wireing harnes for a 51 3100 and dont want to have the same quality I got with the shackles? Help! | | | | | Joined: May 2004 Posts: 45 Member | | Member Joined: May 2004 Posts: 45 | Use the pre-made wiring harness's the streetrod guys have developed. Painless, Black Box, are two that come to mind. These with circuit breakers, labeled wire, correctly sized, long enough and color coded. will end your electrical problems | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | wiring harness options: http://woogeroo.home.mindspring.com/autolinks/wiring.html also click on 'links' above here at the top of the stovebotl page - then click on 'parts' most of the old chevy/gmc truck vendors sell a wiring harness that is made to plug back in if yer keeping it stock or clsoe to stock. If you are adding options and doodads - go like microbe said. -W | | |
