3 members (3B, Snowman51, Shade Baby), 113 guests, and 1 robot.
Topics128,157
Posts1,056,892
Members48,458
I got some after market shackles, they seam to have more play than the ones I took out (made in china),I'm going to send them back, does any one have a good supplier for shackles
I also need a wireing harnes for a 51 3100 and dont want to have the same quality I got with the shackles?
Help!
Use the pre-made wiring harness's the streetrod guys have developed. Painless, Black Box, are two that come to mind. These with circuit breakers, labeled wire, correctly sized, long enough and color coded. will end your electrical problems
Socket Breaker
Socket Breaker
wiring harness options:
http://woogeroo.home.mindspring.com/autolinks/wiring.html
also click on 'links' above here at the top of the stovebotl page - then click on 'parts' most of the old chevy/gmc truck vendors sell a wiring harness that is made to plug back in if yer keeping it stock or clsoe to stock.
If you are adding options and doodads - go like microbe said.
-W
