1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#184037 06/19/2005 9:13 PM
What sheet metal parts if any interchange from 1955-1959 or just 58 and 59, and from gmc-chevy
#184038 06/19/2005 9:53 PM
Socket Breaker
Socket Breaker
I can't swear to it as I have a '65 - but I *think* from the cab back is the same... with the exception of the Tailgate which says gmc instead of chevy.
however, if I'm wrong someone will pipe up.
a piece of advice - when you post a topic - put what year truck, make, model it is - then the guys with knowledge of that year will click on it to see if they can help.
-W
#184039 06/20/2005 1:04 AM
nearly everything from 55-59 interchanges, the difference being that the 58-9 frame is 1/2" longer for the 'gravel pan' right behind the bumper, and the 58-9 front sheet metal is different from 5-7 and the hood hinges mount differently to the cab and inner fenders - 58-9 are entirely interchangeable, the only difference being the trim on hood and fenders, and grill between GMC and Chev - the box is identical 55-66 except for the Chevrolet or GMC on the tailgate - the only cab difference is Chev and GMC dashes and gauges differ
#184040 06/20/2005 3:26 AM
V
V Offline
55 thru 57 fenders and hood are different from58-59 they will interchange if you change out the whole front clip.GMCs have a different dash
#184041 06/21/2005 2:39 AM
How hard is it to put a 1959chevy dash in a 1959 gmc. Am i right in thinking the 59 lookes like the 57 chevy dash.
#184042 06/21/2005 3:57 AM
see yer other post, gmck - the chev dashes 55-59 are all identical, same w/ the gmc dashes, 55-59 alla same
also V6jimmy, the 55/7 front clip is difficult to fit properly on the 58/9 because the hood hinge mount holes on the cab firewall are slightly different - also the front of the 58/9 frame has to be cut about a half inch - 58/9 front clip is even harder to fit to a 55-7 cab/frame and will hang out too far on the frame to fit the bumper
