1 members (baldeagle),
53
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | What sheet metal parts if any interchange from 1955-1959 or just 58 and 59, and from gmc-chevy | | | | | Joined: Feb 2002 Posts: 2,892 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,892 | I can't swear to it as I have a '65 - but I *think* from the cab back is the same... with the exception of the Tailgate which says gmc instead of chevy.
however, if I'm wrong someone will pipe up.
a piece of advice - when you post a topic - put what year truck, make, model it is - then the guys with knowledge of that year will click on it to see if they can help.
-W | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | nearly everything from 55-59 interchanges, the difference being that the 58-9 frame is 1/2" longer for the 'gravel pan' right behind the bumper, and the 58-9 front sheet metal is different from 5-7 and the hood hinges mount differently to the cab and inner fenders - 58-9 are entirely interchangeable, the only difference being the trim on hood and fenders, and grill between GMC and Chev - the box is identical 55-66 except for the Chevrolet or GMC on the tailgate - the only cab difference is Chev and GMC dashes and gauges differ
Bill | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | 55 thru 57 fenders and hood are different from58-59 they will interchange if you change out the whole front clip.GMCs have a different dash | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | How hard is it to put a 1959chevy dash in a 1959 gmc. Am i right in thinking the 59 lookes like the 57 chevy dash. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | see yer other post, gmck - the chev dashes 55-59 are all identical, same w/ the gmc dashes, 55-59 alla same
also V6jimmy, the 55/7 front clip is difficult to fit properly on the 58/9 because the hood hinge mount holes on the cab firewall are slightly different - also the front of the 58/9 frame has to be cut about a half inch - 58/9 front clip is even harder to fit to a 55-7 cab/frame and will hang out too far on the frame to fit the bumper
Bill | | |
