| | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18387 01/14/2002 5:53 AM | Joined: Aug 2001 Posts: 22 Member | | Member Joined: Aug 2001 Posts: 22 | someone once gave me the number of a bearing toa ask for at a shop and i ended up getting the wrong one. this is to keep my stock steering wheel by cuttinh the steering shaft and pressing in a bearing to hold the shaft. Then i will connect the remainder on the shaft to the u joiunt and so on down the line . remember that part number 6 something---- mike
1950 GMC 1/2 TON 1952 3/4 DUALLY 1952 CHEVY FRAME,CAMARO CLIP,327,700R4 WAITING FOR GLORY
#18388 01/14/2002 7:18 AM | Joined: Feb 2000 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 57 | I bought mine from Chevy Duty, I do not know what the part # is though. You can e-mail OR call them and they will know what you need. Since I bought mine, someone told me to go to a Toro lawn mower parts house and they can fix you up with one. I have not verified this though?? [img] http://www.stovebolt.com/bboard/ubb/biggrin.gif[/img]
Kelly 1951 Chevy 3100 1967 RS/SS Camaro
#18389 01/14/2002 7:10 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Go to a bearing shop with your dimensions and they may be able to look one up from that. I think your shaft is common 3/4" for center hole and measure housing ID for outer ID of bearing. I use Bearings Inc, here which has new name of Industrial ***** something now. You will probably have to slot the housing and pull tight with a clamp to hold it in place. Shouldn't need to be real heavy. Fords used a nylon thing in ends of theirs in 70's, that used to fall out after cab brackets went bad and cab fell on steering column! Don't know if they have similar dimensions or not. Try a bearing shop.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
