| | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Can someone post a photo or diagram of the proper setup for the throttle linkage, 49 AD, 216, Carter YF. When I restored my truck the only change I made was the addition of an eyebolt through the hole at the bottom of the block where the spring attaches. Everything seems to work properly but the throttle occasionally hangs and you have to tap the pedal to free it up. The problem could just be a weak spring but I want to make sure everything else is right. BTW, I do not have my throttle cable connected so no binding there. Thanks. | | |
