8 members (Forty9, Joe H, MickeyP, FAST55, 55shaker, 68ironhead, LAROKE, 1 invisible),
63
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 7 Junior Member | | Junior Member Joined: Jun 2005 Posts: 7 | In doing sonme updates on my truck I have come to the rear end ... my donor has been a 68 1/2 ton Chevy pickup and I am going to use this rear end ... will the front drums on this truck slide onto my spindles? Is there any front 6 lug drums that would? Am I losing my sanity? | | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Welcome to the bolt, need more information your donor is a 68 C10 what is your other truck? | | | | | Joined: Jun 2005 Posts: 7 Junior Member | | Junior Member Joined: Jun 2005 Posts: 7 | | | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Keb88 your 57 has 12" brake drums and all the 6 lug drums I have run across are 11" about 20 years ago I changed a 55 2nd 3600 to 6 lug but I changed the whole axle assembly I dont remember if I did this because the spindle was different or if it was because the the other axle Had better king pins. you could use a mic and measure the spindle on both and see if you could modify the backing plate to fit. hope this helps jim | | | | | Joined: Jun 2005 Posts: 7 Junior Member | | Junior Member Joined: Jun 2005 Posts: 7 | Thanks Jim. I will go this direction and see what I find. It will be awhile because we are in the process of moving, but I will let you know what I find. Thanks again and have a great day! Keb | | |
