8 members (GA Boy, 2-Ton, Gray_Ghost, Nick in Manitou, GMCJammer51, Joe H, Andrew_Julio, Jay R),
75
Mod | | | Forums66 Topics128,169 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 2 Junior Member | | Junior Member Joined: Oct 2003 Posts: 2 | Hey Now, I'm looking for a easy/ cheap way to drop the front end of my 42' half-ton. Eaton Springs wants $449.00 a side for 3" drop springs. Don't want to do Mustang or Bags to $$$$. Looking to work with the springs. What have people done in past? Thanks, Mark in Socal
Mark Gansel
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 |
| | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | You can try taking a few of the leafs out of each spring pack. That will usually drop the front end a couple of inches. You can also look into having your stock straight axle dropped 2 to 3 inches in combination with removal of the leafs. Removing the leafs is free and having your axle dropped is about $400. | | | | | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | Whatever you choose, if you don't use the original front springs and you also want to lower the back end, take your old front leafs and put them in the rear, it'll give you 3-4" of drop.
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
