Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Hush), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#183365 06/08/2005 1:51 AM
Junior Member
Junior Member
I have either a 50 or 51 GMC truck but not sure which it is... FCI (or 1 not sure)52... help, please....
#183366 06/08/2005 3:35 AM
You have an FC152 (not I). F = 1947-1950, C = conventional cab, 15 = 3/4 ton, 2 = 125 1/4" wheel base. The 6th through 12th numbers are the number it came off the production line. So, a 1950 3/4 ton sounds about right.
#183367 06/08/2005 3:50 AM
Junior Member
Junior Member
Thank you
Thank You
Thanks!! you are a life saver!!!
