Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
You have an FC152 (not I). F = 1947-1950, C = conventional cab, 15 = 3/4 ton, 2 = 125 1/4" wheel base. The 6th through 12th numbers are the number it came off the production line. So, a 1950 3/4 ton sounds about right.
