5 members (NJC, Bill Hanlon, baldeagle, Peggy M, carbking), 62 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#183159 06/04/2005 9:22 PM
Does anyone know if those steering stabilizer kits that Chevy Duty sells do any good? Thanks, Steve
#183160 06/04/2005 9:27 PM
Riding in the Passing Lane
They do help some. I had one on a 56 I used to have & will probably put one on the 55 I,m working on now. smile
1972 Chevy c10 Cheyenne Super
#183161 06/04/2005 10:08 PM
Thanks..Have all new grease zerks and full of new stuff, a front sway bar, and new monroe gas shocks...It still seems to want to wander a little, but no shimmy..Thanks, maybe try one..Steve
#183162 06/05/2005 5:15 AM
If there's nothing worn out in the front end,you might try adding toe-in,adjust maybe half a turn at a time,test drive,see if it helps. Remember how much you adjust,or write it down,so if it makes it worse or doesn't help,you can set it back to where it was.If that doesn't help,it might be worth it to find an alignment shop that knows I-beam front ends and have it checked.It could need a wedge shim under the axle at each spring to change the kingpin rake.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#183163 06/05/2005 6:13 PM
I had some wander, changed to roller type wheel bearings,added heavy duty tie rod and modern tie rod ends ,new patricks four leaf front springs,and bushings, and sway bar , all fittings greesed ,truck handles like a new truck. old navy 51..........................
