0 members (),
52
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Does anyone know if those steering stabilizer kits that Chevy Duty sells do any good? Thanks, Steve | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They do help some. I had one on a 56 I used to have & will probably put one on the 55 I,m working on now.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks..Have all new grease zerks and full of new stuff, a front sway bar, and new monroe gas shocks...It still seems to want to wander a little, but no shimmy..Thanks, maybe try one..Steve | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If there's nothing worn out in the front end,you might try adding toe-in,adjust maybe half a turn at a time,test drive,see if it helps. Remember how much you adjust,or write it down,so if it makes it worse or doesn't help,you can set it back to where it was.If that doesn't help,it might be worth it to find an alignment shop that knows I-beam front ends and have it checked.It could need a wedge shim under the axle at each spring to change the kingpin rake. | | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I had some wander, changed to roller type wheel bearings,added heavy duty tie rod and modern tie rod ends ,new patricks four leaf front springs,and bushings, and sway bar , all fittings greesed ,truck handles like a new truck. old navy 51.......................... | | |
