| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 1 Junior Member | | Junior Member Joined: Jun 2006 Posts: 1 | Hi All,
Does anyone know the years that the artillery wheels were manufactured? Are all of the years the same? I'm looking at getting some off of a 36, but I don't know if they are original. I'd like to put them on a 40.
Thanks, B
Brian
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The 1936 wheels originally were 17" came with spokes also, but the later 16s or 15s could have been swapped. The most popular artilleries were 39 to 46 +/- and were the 15". I've found these on lots of trucks that had the same 6 lug pattern.
I found some 16" artilleries on late 30s Olds sedans, but I don't think any trucks came with 16s. As long as they are 6 lug, you should be fine. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The 36 GMC 1/2 ton came stock from the factory with 16 X 4 1/2 inch Kelsey Hays artillery wheels. | | | | | Joined: Sep 2003 Posts: 10 New Guy | | New Guy Joined: Sep 2003 Posts: 10 | I have one 16" if you want it. It has slots all the way around instead of the four cutouts. I'll send a picture if you like. Reply to [email protected] if you have questions. Quinn | | |
