5 members (Niels V, Phak1, MNSmith, 2 invisible), 77 guests, and 4 robots.
Topics128,180
Posts1,057,141
Members48,463
Junior Member
Junior Member
Hi All,
Does anyone know the years that the artillery wheels were manufactured? Are all of the years the same? I'm looking at getting some off of a 36, but I don't know if they are original. I'd like to put them on a 40.
Brian
The 1936 wheels originally were 17" came with spokes also, but the later 16s or 15s could have been swapped. The most popular artilleries were 39 to 46 +/- and were the 15". I've found these on lots of trucks that had the same 6 lug pattern.
I found some 16" artilleries on late 30s Olds sedans, but I don't think any trucks came with 16s. As long as they are 6 lug, you should be fine.
1946 1/2-Ton Chevy
The 36 GMC 1/2 ton came stock from the factory with 16 X 4 1/2 inch Kelsey Hays artillery wheels.
I have one 16" if you want it. It has slots all the way around instead of the four cutouts. I'll send a picture if you like. Reply to [email protected] if you have questions.
Quinn
http://www.fatherley.com/trucks.html
Q: Is it transportation or is it yard art?
