| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18290 03/15/2002 4:02 PM | Joined: Mar 2002 Posts: 18 Member | | Member Joined: Mar 2002 Posts: 18 | Anybody know of source(s) for dropped axles for 58 3100 Do they create clearance problems and or other problems with disc brake conversions etc.
Life is to serious to be taken seriously
#18291 03/15/2002 9:10 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | There is a local shop here that does it. I am told they heat your axle to 1700 degrees and pull and bend both sides. Maybe you can find a shop like that where you live. I would check some truck shops, low rider shops, stuff like that.
54 3100 with 235 62 flatbed dump C60 with 261
#18292 05/03/2002 1:55 AM | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | hey I hope this info can help you....I went over to oakland and purchased a 4inch drop axle from more drop axle. here is the info and he has axles in stock.
Mor-Drop Axle 600- 29th ave Oakland california (510)261-1888
It's roughly $100 an inch BUt don't quote me. He has been doing this work for the last 25-30 yrs maybe longer. | | |
