1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#182901 06/02/2005 3:49 AM
Hey all. Maybe somebody can help out. I have installed a 47-55 power steering conversion from chevy duty on my 37...worked like a charm. I just bought a set of tube shock upper and lower mounts for a 47up on e-bay for $26, cheaper than the $250 they wanted for the kit. What shocks fit on the 47 up with tube shocks? I guess it would have to have a stud on each end. How much travel do I need, I'm guessing the same as the distance from the bump stop to the frame. Man it stinks that they don't make much in the way of updates for a 46 and down truck. Mine is the guniea pig as my dad has a 1946 1/2 stored inside since 1975 and we're both keeping the straight axle. I'm going with a 327 and a 4 speed (hydraulic S-10 pedals and a K10 bellhousing). Thanks!!
Dave
Even a blind squirrel gets a nut sometimes!
#182902 06/02/2005 4:01 AM
I just got some from AutoZone. They are Gabriel 81270 for the front. I lowered my truck about 3 inches in the front. So all I did was relocate the upper shock mount a little higher. Worked great. Good luck.
