| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I was working on my headlight and parklight wiring today, and thought that I should check how my new glass park light lenses fit. Well the tabs at the back fit good on top of the headlight bucket, but when I put the parklight housing on I end up with quite a big gap around the top edge. I'am I missing something :confused: like a rubber gasket or is this just more after market blues Thanks: Stuart | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Sublime! Check out Scott's at: http://www.scottssupertrucks.com/ He lists a "housing to head lamp" gasket! I got a couple for my /46. G | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Stuart - There is indeed a gasket that goes under the lense. You can get them from any of the vendors or make your own. I used some 1/8" sheet foam that I found at the materal store in the crafts section. It comes in 8 1/2" x 11' sheets, any color you want. It's closed cell foam and works well. I think I had to use two layers. It might cost you $0.50 for a sheet. George | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | George I have a parklight housing to headlight bucket gasket are you saying that there is a gasket for under the glass lens Thanks | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | Thanks guys I found a picture of what I need | | |
