| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Fire in the hole?  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | M. Smith, I have posted on those horns before too. I have seen enough of em to decide they must be an option on the 41/46 trucks. Mine had a set under the hood too, only without the bracket. I have it from a good source that even if you warn a 5 year old, those dual horns will scare the crap out of em!!  | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | And it looks like your 216 is a 1948 vintage according to American Classic... | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow, that is the engine in that truck? Man, somebody was taking care of that.
I used something called Fluid Film in my cylinders. It comes in a spray can and I find it the best rust breaker that I have used. I jacked up one rear wheel and used it to turn the engine over. I started with just a few degrees of movement and after a day or so, I made it through a whole revolution. Next I used the fan and belt and the last thing I did was turn it over with the plugs out, using the starter. You might want to pull the distributor and turn the oil pump over. Also if it stays stuck, I would pull the valve cover and take the pushrods out. If it is some stuck valves holding things up, you will soon know. | | |
