4 members (78buckshot, JW51, baldeagle, moparguy), 85 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#182653 02/19/2005 9:30 PM
Got the truck home today and working on the engine. It appears to be stuck but I'm soaking it down now. Here is the number on the block: FAA425038, is it the original engine? Check out those horns and bracket. They look original.
[img]http://img.photobucket.com/albums/v27/mismith/feb19414.jpg[/img]
[img]http://img.photobucket.com/albums/v27/mismith/feb19413.jpg[/img]
Mike
#182654 02/19/2005 10:41 PM
Riding in the Passing Lane
Fire in the hole? smile
1972 Chevy c10 Cheyenne Super
#182655 02/20/2005 12:01 AM
M. Smith,
I have posted on those horns before too. I have seen enough of em to decide they must be an option on the 41/46 trucks. Mine had a set under the hood too, only without the bracket.
I have it from a good source that even if you warn a 5 year old, those dual horns will scare the crap out of em!! wink grin
#182656 02/20/2005 12:04 AM
And it looks like your 216 is a 1948 vintage according to American Classic...
#182657 02/20/2005 1:51 AM
Wow, that is the engine in that truck? Man, somebody was taking care of that.
I used something called Fluid Film in my cylinders. It comes in a spray can and I find it the best rust breaker that I have used. I jacked up one rear wheel and used it to turn the engine over. I started with just a few degrees of movement and after a day or so, I made it through a whole revolution. Next I used the fan and belt and the last thing I did was turn it over with the plugs out, using the starter. You might want to pull the distributor and turn the oil pump over. Also if it stays stuck, I would pull the valve cover and take the pushrods out. If it is some stuck valves holding things up, you will soon know.
1951 1 Ton Completed
