5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#182347 05/06/2005 3:21 PM
Now that I have my truck (47 3600 with a 235) back on the road Iv been driving it every day. I was driving it about eight miles to the next town where I was doing my student teaching. I never had a problem. Now that I am subbing in town I don’t get out on the highway, my battery isn't charging. I have an alternator on it so I thought that would take care of the battery even on short runs. Any ideas?
#182348 05/06/2005 6:39 PM
Battery could be bad and therefore not taking a charge. Alternator or regulator could be failing. Grounds might be failing, or wires could be loose.
If you have a one-wire alternator and are using a diode to fool it into working, its overcharging your battery, and the battery may have failed as a result.
I'd encourage you to move this question over to the electrical forum, and provide more details about your electrical system there.
#182349 05/06/2005 7:31 PM
make sure the old fan belt is good and tight,,
Redryder pix
My Hotrod
#182350 05/07/2005 2:28 AM
Thanks, I'll do that.
