1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
Junior Member
Junior Member
Hopefully an easy answer...
I need to reconnect the heater on my '64 C10, which looks like it hasn't been used for years (ex-California!)
I assume you run a larger(5/8" ?) hose from water pump to the larger diameter heater pipe (which enters the heater box to the rear) and fit a smaller (1/2" ?) hose from the small heater pipe back to the thermostat housing?
Is this the correct in/out plumbing?
Thanks guys, Limey
On my 64 I have 3/4" hose from water pump and 5/8" from intake manifold. No problems I know of and the heat will run you out of the cab. Hope this helps.
Sittin' Pretty in My Old Kentucky Home.
http://www.picturetrail.com/barneysbowtie
Junior Member
Junior Member
Thanks Kentrucky - I could use some heat in the cab as snow is forecast!
Is the heater element easy to remove to test it? - don't want a cab full of water if it turns out it leaks!
Well, this is my first project, so I'm learning as I go, and everything is "the first time" for me...but I just started taking it apart til I had everything on the bench...cleaned out the mouse nests...repainted...and reassembled...then put it back where I found it. wink
Seemed easy enough...but maybe I got lucky!
Junior Member
Junior Member
Stripped my heater out on Saturday and the heater core is burst (lucky I didn't connect it). At least I had a chance to remove 40 years of muck, and the fan still runs!
Limey
