1 members (Hotrod Lincoln), 89 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#18207 01/27/2004 10:07 PM
V
Junior Member
Junior Member
V Offline
Does anyone know if the spindles are the same for a 1/2 ton and 3/4 ton '58 Chevy Apache pickup truck?
I would like to order one of the disk brake sets, but I have a 3/4 pickup and was wondering if I would be running into any problems with the spindles.
Thanks.
Von Tingler
#18208 01/27/2004 10:38 PM
The 3/4 ton spindles are not the same. they take a larger kinpin (around .9800" compared to .8500") and the bushings are a pressed-in type whereas the 1/2 ton is 'push-in'.
r
Every once in a while, life gets a little more surreal.
#18209 01/28/2004 1:18 AM
V
Junior Member
Junior Member
V Offline
Hey thats good to know.
Thanks for the info. But I guess I was wanting a little different information about 3/4 ton spindles.
I guess I should ask the question in a different way .
Will I have any problems when ordering a disk brake kit for my 3/4 ton spindles?
Or, am I going to have to go to a 1/2 ton set up up front?
Thanks.
