9 members (cmayna, Nick in Manitou, Hanks custodian, RdsLessTaken, homer52, Gdads51, mick53, kurbside bolter, 1 invisible),
79
Mod | | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18207 01/27/2004 10:07 PM | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | Does anyone know if the spindles are the same for a 1/2 ton and 3/4 ton '58 Chevy Apache pickup truck?
I would like to order one of the disk brake sets, but I have a 3/4 pickup and was wondering if I would be running into any problems with the spindles.
Thanks.
Von Tingler | | |
#18208 01/27/2004 10:38 PM | Joined: Jan 2004 Posts: 7 Member | | Member Joined: Jan 2004 Posts: 7 | The 3/4 ton spindles are not the same. they take a larger kinpin (around .9800" compared to .8500") and the bushings are a pressed-in type whereas the 1/2 ton is 'push-in'. r
Every once in a while, life gets a little more surreal.
#18209 01/28/2004 1:18 AM | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | Hey thats good to know. Thanks for the info. But I guess I was wanting a little different information about 3/4 ton spindles.
I guess I should ask the question in a different way .
Will I have any problems when ordering a disk brake kit for my 3/4 ton spindles?
Or, am I going to have to go to a 1/2 ton set up up front?
Thanks. | | |
